For Sale – 2003 Sea Pro SV2300 Bay Boat
For sale is my 2003 Sea Pro SV2300 Bay Boat. She has been a loyal companion for 6 years.
I purchased this boat new in November of 2002 from Chatlee in Sanford.
We are looking to move up and decided now is the time (been bitten by the offshore bug.) I am not interested in any trades.
This boat has been meticulously maintained and is well equipped with all the goodies you need for some serious catching and family fun. All you need is some tackle and you are ready to roll.
The boat is located in Sanford NC and I am willing to take her to Jordan Lake for sea trails (serious buyers only.)
2003 Sea Pro SV2300
Specifications
LOA 23 foot 4 inches
Beam 102
Dry Weight 2000
Fuel Capacity 85 gallons
Draft 12 inches
Deadrise at transom 16 degrees
Maximum Horse Power 250
Recommended Horse Power 200
Features
All composite construction
Cooler seat with swing back rest
4 bow 8 foot Bimini Top
Dual batteries with Perko 1-2-Both-Off switch (house circuit uses Yamaha AUX charge lead)
Raw Water Wash Down
Bait Sentry Livewell pump
Front and rear livewells
Bilge pump and float switch replaced in 2008
Standard cushion package (forward rod box, forward fish box, front livewell bottom and back
Front casting deck swivel seat
Swim step with telescoping ladder
8 Cabela’s HT360 rail mount rod holders
Electronics
Garmin 2010C Color GPS/Fishfinder (no maps provided, you will need to purchase a chip)
Garmin GSD20 Sounder module
Garmin GPS17N GPS antenna on stainless ratchet mount
Airmar P66 Dual Frequency transom mount transducer with speed and temp
Standard Horizon Quest VHF Radio (Standard DSC features, no polling)
Digital Antenna Model 529 on stainless ratchet mount
Wired to receive GPS coordinates from the 2010C
Poly Planar MRD-60 AM/FM/CD (just replaced with a refurb unit)
Poly Planar MR-4056 Speakers mounted on the sides of the center console (replaced March 2009)
Poly Planar AUX Input module (one channel is for the VHF radio and one channel is used for a MP3 player plug-in)
NorthStar F210 Fuel Flow Meter
Minn Kota Riptide 65 PowerDrive/AutoPilot/CoPilot
Mounted with the Ultimate Trolling motor mount (has a “deployed” and “stowed” position)
2 group 33 deep cycle trolling batteries mounted in boxes under the front casting deck
ConnectPro trolling motor plug and receptacle (twist lock)
ProMariner 20 amp (10/10) onboard charger
1 wireless key fob transmitter
Foot pedal control with 18 foot cord (only used twice)
Replaced the compass board and the main board last fall with the newer updated epoxy coated boards
Motor
2003 Yamaha F200 Four Stroke
1300 hours (90 percent below 1000 RPMs, slow trolling for stripers and kings)
All filters replaced and VST cleaned March 2009
Spark plugs replaced March 2009
Complete water pump kit replaced March 2009
Replaced thermostats March 2009
Replaced poppit vavle March 2009
Replaced control cables and binnacle September 2008
Prop Michigan Wheel Apollo II 151/4 19 pitch stainless
Skegard Stainless Steel skeg protector
Cruise 35 mph @ 4000 RPMs 7 gallons per hour
WOT 48 mph @ 6000 RPMs 13 gallons per hour
Trailer
2003 Wesco Aluminum I-Beam Tandem Axle with Surge Brakes
Steel belted radial tires
Bias ply spare (not mounted)
New Kodiak S-Cad disc brakes (integrated hub rotor)
New rear idler hubs
Guide on posts
Boat Buckle transom tie downs
Boat Buckle bow tie down
Rewired trailer and added dedicated ground March 2007 (tow vehicle needs standard 7 pin round receptacle)
Optronics LED lights all around with amber marker lights on the guide on posts to adhere to NC trailering laws
Additional Items that go with the boat
4 standard life vests
1 throw cushion
13 pound fluke style anchor with 25 foot of chain and 100 foot of rode (it hooks very nicely)
4 braided dock lines
2 Taylor Made fenders with rail clips
Kiddie fire extinguisher
25 foot hose for wash down
Telescoping paddle/boat hook
$20,000
Inquires should be directed to: hotspot@bogueinletnc.com[/b]
Thanks for looking.
This boat has been exteremly well maintained. I haven't seen a used boat this well maintained. I've been on it several times. Its hard to find a boat that does it all, but this boat comes close. Perfect for the hard core fisherman or a leisurely day out with the family. Some people like to buy brand new boats, but with that you have the break in periods and getting all the littlle bugs worked out. By the time all that is done the boat has spent more time in the shop than on the water. This boat is ready to get you out on the water more.
Service work done in March of 2009:
Replace Thermostats
Replace Poppit Valve
Lower Unit Lube Change
Replace Spark Plugs
Remove VST, clean and replace filter
Replace F-Shaped filter
Replaced Engine Filter/Water Separator
Replaced Racor Filter
Had Injectors Cleaned and Tested (replaced 2)
I need to sell this fine lady so I can start my search.
REDUCED TO $19,000
Question: Do the downriggers come with the boat and what kind are they?
Answer: Yes, they come with the boat. They are Cannon HP Uni-Trolls with the swivel base and telescoping boom. They have been upgraded to the new style 1-piece spool and are spooled up with 200 pound Power Pro with a stainless steel snap hook. Three 8 pound balls included, 2 of them have release clips.
