How Long Should It Take An F150 To Pee On Muffs
  • Replies 21
Try a tub, stock tank, garbage can.
My experience with Yam 150's has been that sometimes they will pee from muffs, and sometimes they wont.
I used a tub at the end of last season since the water was already off at my marina and it worked well, but the water is on now so I gave the muffs (dual feed) a try.
One more try with the engine tilted and I guess its back to the tub. Will it hurt the engine to run 5 to 8 seconds with the muffs on waiting for the stream?
I just want to burn off the fogging oil before putting in new plugs.
Are you sure it is OK to run a Yamaha 150 at 45 degrees? Engine manufacturers have a maximum limit for tilting the engine while running. I am not sure what it would be for a Yamaha F150. Oil pickup can be a problem with most manufacturers at high angles.
Good point. Maybe I'll just change the plugs and run it in the water.
