Garmin 740 & Standard Horizon GX2100 install
I removed my Garmin 2206 and ICOM 504 both working great and on their way to a new owner. They've served me well for the last 4.5 years.
Adding a Standard Horizon GX2100 VHF/AIS combo and a Garmin 740 with a GXM 51 smart antenna. As usual I bought everything from BOE .... you just can't beat their service and prices. Thanks Jim.
I'm fortunate in as much as I can install all the equipment off the boat and then take it to it when I'm finished. I connected everything up including the GXM 51 to test it out. While I had it on I called XM and cancelled my subscription for my GXM 31 connected to my Garmin 545 and added the GXM 51. The whole process including the call to XM and getting weather data on my 740 took 30 minutes start to finish.
Here's some pictures of the new install. :605_thumbs_up:
23.jpg?t=1274408872
3-1.jpg?t=1276091951
4-1.jpg?t=1276092020
22-1.jpg?t=1276092841
21-1.jpg?t=1276092887
Initial install .......
7.jpg?t=1276092095
1.jpg?t=1276092140
2.jpg?t=1276092189
4.jpg?t=1276092237
The Garmin 740 and SH GX2100 are good products and have easy to use and understand display functionalities. The NMEA 0183 was easy to connect and provides a host of interactive AIS data via the GX2100.
Here are some videos of the 740's capablities.
Garmin 740 Display Functionalities
Fishing Charts .........
584.jpg?t=1276092521
XM Weather Display GX51 Smart Antenna .....
7920.jpg?t=1276092582
G2 Vision Fish Eye View .........
726.jpg?t=1276092636
G2 Vision Mariners Eye Views
640.jpg?t=1276092703
3483.jpg?t=1276092791
Screen Views .......
4440.jpg?t=1276092958
3774.jpg?t=1276093054
There you go. Both units were easy to install and had good solid install instructions.
I like your work and info, quick question what type of board did you use. Also what did you coat it with? I find it hard to spend almost $50 every time I change the lay out in my ebox for new piece of starboard. I probally went thru $150 in starboard for the inside of my ebox, in the past 3 years I have owned my boat.
Jay
Edited by wiredawg
Jay
Jay .....
Thanks for the compliment.
I used a half inch thick piece of oak that was 24 x 12 inches to start with which is the same type of wood in the used in my previous install. Served me well for 4 + years. I sprayed it with Valspar flat black paint from Lowes (5 coats). I put a little over 2200 hours on my Whaler with the previous install and no issues whatsoever. I fish offshore so it was put to the test on more than one ocassion.
Here's what my previous install looked like ... I removed the two pieces inside the electronics box.
ICOMComandMic32Install1.jpg?t=1276135467
Once I get my Whaler back ... having some glass work done ... it will just a matter of crawling in the space under my helm and installing the backboard. The electrical connections will be easy all I have to do is connect them to my fuse block.
BEP7161.jpg?t=1276136120
I'm fortunate in that I have alot of space under my Helm area ... I can actually sit in there comfortably.
SHICOM2.jpg?t=1276136369
Edited by bluewaterpirate
Tom....I'm putting a Garmin 740s on a new Bluewater that should be completed in a couple of weeks. Does the GXM 51 smart antenna serve as an antenna for both XM radio and the GPS?
Thanks BOZ .....
Bill .....
The GXM 51 Smart Antenna provides both XM Weather and Music output. I'll take some pictures of the connectivity later this afternoon. It's a real easy connecttion.
Here you go ..........
Pictures are worth a 1000 words. The GXM 51 connectivity is straight forward. Once you get your NMEA 2000 backbone installed you connect the NMEA 2000 wire from the the GXM 51 antenna to it.
In this picture you can see the Garmin 740 is also connected to the backbone so any NMEA 2000 device connected to the backbone will send data to your 740. The green dot indicates where my GXM 51 connects and the yellow dot where my NMEA 2000 power source connects.
3-1-1.jpg?t=1276448857
Here's what the GXM 51 connectors look like.
1-2.jpg?t=1276449033
2-2.jpg?t=1276449073
3-2.jpg?t=1276449113
This is what your XM displays look like on the 740.
System display .... everything working normally.
1-3-1.jpg?t=1276449436http:
XM Music control display .....
6-1.jpg?t=1276449558
There you go .......
