setting drags
i'm trying to figure out where i need to set the drags on my reels vs line strength. all i've ever done is made sure that i could pull line without breaking it, i'm getting a little more serious now, so i want to do everthing correctly.
thanks for the input
Yep, 1/4 up to 1/3 of the line's "test", unless you use braid. Braid's breaking strength is usually higher than mono for most applications. For instance I use 80lb test braid for bottom fishing, but my reel will not give me 26lbs (1/3) of drag. I set that drag for 20lbs.
so you would set your maximum full lock up to 1/3 or just where you leave it set while under troll?
in other words, lets say your concerned about being spooled, would 1/3 of line test still be the most, or would you leave some drag available to go up to 1/2 or 2/3 breaking strength?
Edited by eliteftlaud
1/3 rd at normal strike setting leaves more drag at full, probably about 2/3 rds of line strength.
quote name='eliteftlaud' date='05 April 2010 - 07:36 PM' timestamp='1270514212' post='32416']
      14,196
