Are you using your engine's Aux charging capability?
  • Replies 20
Posted Images
I ordered the kit and it came with a built in fuse. I believe there are two versions, mine was about $100 from sim and from Yamaha.
I was also told by my local yamaha service manager that without the auxillary charging hooked up a problem can be created on the yamaha charging circut? Has anyone ever had this problem?
Must be a little different. No fuses on mine, just a wire in a sheath and two connectors on either end.....about $80 retail from the Yami dealer.
The last time I rigged this up, on the advice of the mechanic at the Yami shop, I made my own charging wire using the plug that gets removed from the charging lead. This time I was in a hurry to get offshore so plunked down the cash. Both have worked equally well.
This is all news to me. Does my 2004 Yam F115 have a factory Aux charging lead someplace?
I would not do that. The AUX charge lead is designed for a house circuit of 12 volts. Most trolling motor applications are either 24 volt or 36 volt. However, if you have a 12 volt trolling motor, go for it, but do not tie the trolling battery and house battery together if you have both.
FWIW - For you Suzuki owner's out there- my 2007 Suzuki DF150 also features the aux charger. You have to move a fuse and add a charging wire to use. Plugged aux wire is pink and located under ECM. If you need detail on fuse placement PM me.
Pre-assembed charging wire setup runs around $80 to 90 bucks or you can fabricate one yourself.
You can run all your electronics and 'toys' on one battery, and use the other for motor starting only.
JC :1992_beer_cheer:
It has what now? I've never heard of any of the Suzukis having dual charging EXCEPT for the DF300 (and its sibling 250SS)... ?
Details / Link ?
Edit: Hmm, found this... Interesting. Looks like this exists for the DF150, 175, 250SS, and 300 - but not for the DF200, 225 or 250. (older engine designs)
http://www.suzukimarine.com/sr_08/_m/acces.../controlbox.pdf
Battery Isolator Lead Set
33830-96J00 Used for charging auxillary
battery DF150/175
