Bronze Thru Hull Fitting Installation and Location?
I am about to start installing a AC unit in my 1991 31' Tiara Open. I am wondering if there is a certain location were I should drill my hole through the hull? I would like to use the same location that the factory uses on boats that came equipped with AC.
I was told to research this carefully before drilling.
Also is there any special method for drilling this hole?
I would assume 3M 5200 sealant would be a adequate.
Any input would be appreciated.
Is the bilge in the mid-cabin below the settee cushion available? I used to install the pickup, strainer, and pump in this area on 32 and 34 Stamas'. The air handler went under the v-berth fwd.
But have you contacted Tiara as far as ascertaining the original location. There shouldn't be any issues with the hull bottom, unless it was cored, which I doubt...
