Garnib 4000/5000 weather setup help
1- Furuno NavNet 3D MFD 12"
-4K Radar dome
-Sounder box with 1K ducer glassed in
-GPS antenna with chart
-Flush mount unit in dash
2- Garmin 4212
-Satellite weather
-Flush mount in dash
3- Standard Horizon VHF Radio
-Digital antenna
-Interface to GPS'
4- Electronics cover
- White stamoid
5- Jensen Marine Stereo
-Four poly planner speakers
-Satellite integrated to Garmin
6- GHP 10 Autopilot
-All hydraulic fittings
-Intergraded to GPS
You should be able to navigate to one of the menu screens, (I forget which one) and it should display the level of the weather that is active. On mine is shows the Fisherman. The other thing is to make sure all the weather settings are enabled. On my 3210, each individual setting needs to be configured for the range. The range can be off, auto or preset to a distance. I never really bothered to figure out what the range selections do, I just keep mine it auto.
Just got the weather working on my new 4212. Called the XM people the night before and had it activated. Went down the next day and fired it up for 1 1/2 hours and had nothing. Called XM, they then informed me I had a window of three hours to fire it up or it would deactivate. They did a refresh, I turned it on and about 45 minutes latter everything worked. So make sure you turn your unit on within 3 hours of activation.
  • 3 weeks later...
Had a "refresher signal" sent. No dice again. Just the small spinning thing up top. Not sure what else I can do. Tried every level. Killing me!
Had the same problem. I found that the weather takes about 3-4 mins to come up on the screen after the unit is first on. I pick weather/precip and go do something for a few minutes. When I come back the rain and clouds (if selected) are on the screen.
Dave
      14,196
