Maritime type sayings-Post Yours
heres a few
"Fair wind and following seas..."
and one of my favorite 'rules', "The law of gross tonnage"
"We are holding our own" Last words from Capt McSorley on the Fitzgerald to the Anderson, her lights went out of sight a few minutes later.
"I/he/she can make that boat dance"
Anyone know why port is port and stbd is stbd? I heard it a while back, it's a fun story. Not sure if it's really true though. Sounds like it could be.
I've heard several versions; here's one from Wikipedia:
The origin of the term comes from early boating practices. Before ships had rudders on their centrelines, they were steered by use of a specialised oar. This oar was held by an oarsman located in the stern (back) of the ship. However, like most of the rest of society, there were many more right-handed sailors than left-handed sailors. This meant that the steering oar (which had been broadened to provide better control) used to be affixed to the right side of the ship. The word starboard comes from Old English steorbord, literally meaning the side on which the ship is steered, descendant from the Old Norse words stýri meaning “rudder” (from the verb stýra, literally “being at the helm”, “having a hand in”) and borð meaning etymologically “board”, then the “side of a ship”.
Similarly, the term for the left side of the boat, port or larboard, is derived from the practice of sailors mooring on the left side (i.e., the larboard or loading side) as to prevent the steering boards from being crushed. Because the words larboard and starboard sounded too similar to be easily distinguished, larboard was changed to port.
As the late Paul Harvey would have said ~~ "And now you know....the rest of the story."
Think you know the ropes? Check this list chock a block with maritime history!
Over the Barrel -
The most common method of punishment aboard ship was flogging. The unfortunate sailor was tied to a grating, mast or over the barrel of a deck cannon.
To Know the Ropes -
There was miles and miles of cordage in the rigging of a square rigged ship. The only way of keeping track of and knowing the function of all of these lines was to know where they were located. It took an experienced seaman to know the ropes.
Dressing Down -
Thin and worn sails were often treated with oil or wax to renew their effectiveness. This was called dressing down . An officer or sailor who
was reprimanded or scolded received a dressing down.
Footloose -
The bottom portion of a sail is called the foot. If it is not secured, it is footloose and it dances randomly in the wind.
Booby Hatch -
Aboard ship, a booby hatch is a sliding cover or hatch that must be pushed away to allow access or passage.
First Rate -
Implies excellence. From the sixteenth century until steam powered ships took over, British naval ships were rated as to the number of heavy cannon they carried. A ship of 100 or more guns was a First Rate line-of-battle ship. Second rates carried 90 to 98 guns; Third Rates, 64 to 89 guns; Fourth Rates, 50 to 60 guns. Frigates carrying 20 to 48 guns were fifth and sixth rated.
Pipe Down -
Means stop talking and be quiet. The Pipe Down was the last signal from the Boson's pipe each day which meant lights out and silence .
Chock-a-block -
Meaning something is filled to capacity or over loaded. If two blocks of rigging tackle were so hard together they couldn't be tightened further, it was said they were Chock-a-Block .
Leeway -
The weather side of a ship is the side from which the wind is blowing. The Lee side is the side of the ship sheltered from the wind. A lee shore is a shore that is downwind of a ship. If a ship does not have enough leeway it is in danger of being driven onto the shore.
Windfall -
A sudden unexpected rush of wind from a mountainous shore which allowed a ship more leeway.
Groggy -
In 1740, British Admiral Vernon (whose nickname was Old Grogram for the cloak of Grogram which he wore) ordered that the sailors' daily ration of rum be diluted with water. The men called the mixture grog . A sailor who drank too much grog was groggy .
Three Sheets to the Wind -
A sheet is a rope line which controls the tension on the downwind side of a square sail. If, on a three Amsted fully rigged ship, the sheets of the three lower course sails are loose, the sails will flap and flutter and are said to be in the wind . A ship in this condition would stagger and wander aimlessly downwind.
Pooped -
The poop is the stern section of a ship. To be pooped is to be swamped by a high, following sea.
As the Crow Flies -
When lost or unsure of their position in coastal waters, ships would release a caged crow. The crow would fly straight towards the nearest land thus giving the vessel some sort of a navigational fix. The tallest lookout platform on a ship came to be know as the crow's nest.
Buoyed Up -
Using a buoy to raise the bight of an anchor cable to prevent it from chafing on a rough bottom.
By and Large -
Currently means in all cases or in any case. From the nautical: by meaning
into the wind and large meaning with the wind: as in, By and Large the ship handled very well.
Cut and Run -
If a captain of a smaller ship encountered a larger enemy vessel, he might decide that discretion is the better part of valor, and so he would order
the crew to cut the lashings on all the sails and run away before the wind. Other sources indicate Cut and Run meant to cut the anchor
cable and sail off in a hurry.
In the Offing -
Currently means something is about to happen, as in - There is a reorganization in the offing. From the 16th century usage meaning a good distance from shore, barely visible from land, as in - We sighted a ship in the offing.
Skyscraper -
A small triangular sail set above the skysail in order to maximize effect in a light wind.
The Bitter End -
The end of an anchor cable is fastened to the bits at the ship's bow. If all of the anchor cable has been paid out you have come to the bitter end.
Toe the Line -
When called to line up at attention, the ship's crew would form up with their toes touching a seam in the deck planking.
Back and Fill -
A technique of tacking when the tide is with the ship but the wind is against it.
Overhaul -
To prevent the buntline ropes from chaffing the sails, crew were sent aloft to haul them over the sails. This was called overhauling.
Slush Fund -
A slushy slurry of fat was obtained by boiling or scraping the empty salted meat storage barrels. This stuff called slush was often sold ashore by
the ship's cook for the benefit of himself or the crew. The money so derived became known as a slush fund.
Bear Down -
To sail downwind rapidly towards another ship or landmark.
Under the Weather -
If a crewman is standing watch on the weather side of the bow, he will be subject to the constant beating of the sea and the ocean spray. He will be under the weather.
Overreach -
If a ship holds a tack course too long, it has overreached its turning point and the distance it must travel to reach it's next tack point is increased.
Gone By the Board -
Anything seen to have gone overboard or spotted floating past the ship (by the board) was considered lost at sea.
Above Board -
Anything on or above the open deck. If something is open and in plain view, it is above board.
Overwhelm -
Old English for capsize or founder.
Between the Devil and the Deep Blue Sea -
The devil seam was the curved seam in the deck planking closest to the side of the ship and next to the scupper gutters. If a sailor slipped on
the deck, he could find himself between the devil and the deep blue sea.
The Devil to Pay -
To pay the deck seams meant to seal them with tar. The devil seam was the most difficult to pay because it was curved and intersected with the straight deck planking. Some sources define the devil as the below-the-waterline-seam between the keel and the adjoining planking. Paying the Devil was considered to be a most difficult and unpleasant task.
Rummage Sale -
From the French arrimage meaning ship's cargo. Damaged cargo was sold at a rummage sale.
A Square Meal -
In good weather, crews' mess was a warm meal served on square wooden platters.
Son of a Gun -
When in port, and with the crew restricted to the ship for any extended period of time, wives and ladies of easy virtue often were allowed to live aboard along with the crew. Infrequently, but not uncommonly, children were born aboard, and a convenient place for this was between guns on the gun deck. If the child's father was unknown, they were entered in the ship's log as son of a gun .
Overbearing -
To sail downwind directly at another ship thus stealing or diverting the wind from his sails.
Taking the wind out of his sails -
Sailing in a manner so as to steal or divert wind from another ship's sails.
Let the Cat Out of the Bag -
In the Royal Navy the punishment prescribed for most serious crimes was flogging. This was administered by the Boson's Mate using a whip called a cat
o' nine tails. The cat was kept in a leather or baize bag. It was considered bad news indeed when the cat was let out of the bag. Other sources attribute the expression to the old English market scam of selling someone a pig in a poke (bag) when the pig turned out to be a cat instead.
No Room to Swing a Cat -
The entire ship's company was required to witness flogging at close hand. The crew might crowd around so that the Boson's Mate might not have enough
room to swing his cat o' nine tails.
Start Over with a Clean Slate -
A slate tablet was kept near the helm on which the watch keeper would record the speeds, distances, headings and tacks during the watch. If there were no problems during the watch, the slate would be wiped clean so that the new watch could start over with a clean slate.
Taken Aback -
A dangerous situation where the wind is on the wrong side of the sails pressing them back against the mast and forcing the ship astern. Most often this was caused by an inattentive helmsman who had allowed the ship to head up into the wind.
At Loggerheads -
An iron ball attached to a long handle was a loggerhead. When heated it was used to seal the pitch in deck seams. It was sometimes a handy weapon
for quarreling crewmen.
Fly-by-Night -
A large sail used only for sailing downwind and requiring rather little attention.
No Great Shakes -
When casks became empty they were shaken (taken apart) so the pieces, called shakes, could be stored in a small space. Shakes had very little value.
Give (someone) a Wide Berth -
To anchor a ship far enough away from another ship so that they did not hit each other when they swung with the wind or tide.
Cut of His Jib -
Warships many times had their foresails or jib sails cut thinly so that they could maintain point and not be blown off course. Upon sighting thin foresails on a distant ship a captain might not like the cut of his jib and would then have an opportunity to escape.
Garbled -
Garbling was the prohibited practice of mixing rubbish with the cargo. A distorted or mixed up signal or message was said to be garbled.
Press Into Service -
The British navy filled their ships' crew quotas by kidnapping men off the streets and forcing them into service. This was called Pressment and was done by Press Gangs.
Touch and Go -
This referred to a ship's keel touching the bottom and getting right off again.
Scuttlebutt -
A butt was a barrel. Scuttle meant to chop a hole in something. The scuttlebutt was a water barrel with a hole cut into it so that sailors could
reach in and dip out drinking water. The scuttlebutt was the place where the ship's gossip was exchanged.
I was on the news a few years back, when they were reporting on a Noreaster blowing through... Absent-mindedly, when the reporter asked me what precautions we were taking, I actually said "Well, we are just tightening up the lines and Battening down the hatches..." :1898_: I actually was caught on tape...
