Daiwa SLT50 Tournament & Pinnacle Marine Custom Rod
You are looking at a pair of used but not abused Daiwa SLT50 Tournament Sealine spooled with 700 yards 200lb Spiderwire mounted on a 5'-6" Pinnacle Marine Outfitters 20-50lb rod.
Reels comes with original Daiwa box.
$389 each or $349 w/o the rod
From their dual disc wet drag to custom features like a main shaft bearing stabilizer (sleeved spool) that normally requires expensive, custom machining with other brands, these reels are ready to go, right out of the box, to tackle some of the most respected game fish on the planet.
Daiwa Sealine Tournament 2-Speed Big Game Reels Features:
Easy shifting, two-speed gearbox. Pull in over a yard of line with every crank or quickly shift into low for raw winching power. Optimized mechanism features fewer moving parts for maximum reliability
Four CRBB extra corrosion resistant bearings
Infinite Spin™ free spool for maximum casting of live baits and hardware
Dual-disc drag sandwiches stainless rotor between two wet discs for up to 50% more surface area, smooth, consistent performance
Preset drag adjustment with precision click feel
Dual-point gear shaft support for maximum winding power and reliability
Main shaft bearing stabilizer prevents excessive side pressure on spool bearings regardless of drag tension
Unitized, one-piece aluminum frame, ultra strong and torque-free
Machined aluminum spool
Massive, stainless steel gears
Stainless steel rod clamp with lanyard ring
Oversized, comfort-contoured aluminum handle knob
Custom features already built-in.
___________________________________________________________________________
Pinnacle Marine Outfitters custom rod - ST-165ARSD
20 - 50 lbs
<img src="http://i709.photobucket.com/albums/ww94/aeroguyplus/DAIWASLT20009.jpg" border="0" class="linked-image" /> <img src="http://i709.photobucket.com/albums/ww94/aeroguyplus/DAIWASLT50001.jpg" border="0" class="linked-image" /> <img src="http://i709.photobucket.com/albums/ww94/aeroguyplus/DAIWASLT50002.jpg" border="0" class="linked-image" /> <img src="http://i709.photobucket.com/albums/ww94/aeroguyplus/DAIWASLT50003.jpg" border="0" class="linked-image" /> <img src="http://i709.photobucket.com/albums/ww94/aeroguyplus/DAIWASLT50004.jpg" border="0" class="linked-image" /> <img src="http://i709.photobucket.com/albums/ww94/aeroguyplus/DAIWASLT50005.jpg" border="0" class="linked-image" /> <img src="http://i709.photobucket.com/albums/ww94/aeroguyplus/DAIWASLT50006.jpg" border="0" class="linked-image" />
Edited by SoFlo2008
