Daiwa LD30-II 2 Speed lever drag & Pinnacle Marine Custom Rod
You are looking at a matched pair of used but not abused Daiwa LD30-II Two Speed Lever Drag Sealine Reels spooled with 350 yards 50 lb Mono mounted on a 5'-6" Pinnacle Marine Outfitters 20-50lb rod.
The reels come with the original Daiwa box and have not been used very much.
$275 each
Daiwa Sealine SLD30II
Graphite and aluminum construction combined for a strong and light 2 speed reel that's at home on the rail. We are very impressed with Daiwa's much awaited graphite and aluminum body 2 speed. These reels feature a unitized aluminum frame and left sideplate for enhanced strength and a dual disc drag with wet discs sandwiching a stainless rotor. They also feature Daiwa's CRBB bearings for extra corrosion resistance on the spool bearings plus four shielded stainless steel bearings (total of six). The unitized aluminum frame and left sideplate provide maximum strength and rigidity. The reels are "old school" like their tournament model above in terms of their shifting mechanism. They use the Penn-style handle pull-out design that's proven functional if not necessarily stylish. Their use of the aluminum frame enhancement is another proven feature.
* Six Sealed Stainless Steel Ball Bearings
* Daiwas CRBB super corrosion resistant spool bearings
* InfiniSpin
* Two Speed Retrieve
* Dual Disc Drag
* Aluminum Frame and Side Plate
* Machined Aluminum Spool
* High Tensile Strength Stainless Steel Gears
* Built-in Spook Bearing Support
* 4.1:1 and 1.7:1 Gear Ratio
* Reel weight 42.0 oz
___________________________________________________________________________
Pinnacle Marine Outfitters custom rod - RGE-168S
20 - 50 lbs
DAIWASLT30-II002.jpgDAIWASLT30-II003.jpg%7Boption%7Dhttp://i709.photobucket.com/albums/ww94/aeroguyplus/DAIWASLT30-II004.jpg[/i
      14,185
