sold my outboard motors and Chevys, no longer have a need for these spare parts.
FOR SALE:
Email Me with your REAL name and Email address or I will not respond at Capt at WickedGoodOutdoors d o t com •(Southern MAINE! can ship to you)
I sold my outboard motors and Chevys, no longer have a need for these spare parts.
Bunch of new & Used Outboard Boat Parts and Other Things for sale.
Make me an Offer for One part or the WHOLE LOT!
Send me an Email with your Real E mail
Capt a t WickedGoodOutdoors dat c o m
and Ill respond with lists of stuff and pictures
Parts for outboards (Can ship)
use your real Email address Ill send you a list of everything I have and pictures.
Outboard Motor Parts for OMCs JOHNSON 60,70,85,90,100,110,115,130,150 hp outboards. And others
90 Degree loopcharged years 1985 thru 1998
And some other items. (Outboard Motor parts came from a closed repair shop down in Mass)
Email Me at Capt at WickedGoodOutdoors DOT com
QTY DESCRIPTION New/Used Price Ea.
New Ignition Keys for Mercury/Force outboards! Various keys.
1 Teleflex SeaStar steering Hydraulic Helm Tel Part# hh5271 1.7, 6.9mpa 100psi $320
3 "Water Pump Impeller Teleflex 18-3056 Impeller - Dia. 3 1/2"",Dpth. 1 1/4"" - 6 Fins - Neoprene
Honda # 06192-ZW1-00 Fits Honda 75HP and Mercs 4743026-2 and others.
" New $10
4 Johnson/Evinrude New Stainless Steel Steering arms for outboards ( Will fit other brands) New $40
1 Johnson/Evinrude Tilt Pins retainer Bars for Johnson/Evinrudes ( Will fit other brands) New $8
2 Johnson/Evinrude VRO hose & Pump & Sender unit New $90
1 Johnson/Evinrude Alum TRIM TAB 327640 OMC New $20
1 Johnson/EvinrudeVRO Kit Part # 438406 includes Pump #175161 New $250
1 Johnson/Evinrude Zinc Skeg trim tab New $20
1 Johnson/Evinrude drive shaft New $70
3 Johnson/Evinrude #323664 Spline Gear New $70
3 Helical Lower unit Gear sets 340490 New $75
1 Johnson/Evinrude New Rectifier/Regulator Kit #CD4 583110 9GR-0A New $100
1 Johnson/Evinrude New Rectifier/Regulator Kit # 395391 New $100
1 Johnson/Evinrude Ignition Coil Kit # 583737 New $50
2 Johnson/Evinrude Ignition coils #582508-0560-0A New $20
2 Johnson/Evinrude POWER PACKS OMC CD4 584027 New $75
1 Johnson/Evinrude Voltage Regulator Kit # 173640 New $140
2 Johnson/Evinrude Timer Base Kit #583376 New $140
1 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs New $70
1 Johnson/Evinrude Water Pump Impellers for 85-150 HP New $12
1 Johnson/Evinrude Complete Water Pump kit for ? HP #391391 New $50
1 Johnson/Evinrude CompleteWater Pump kit for 85-150 HP Part # New $50
2 Johnson/Evinrude Evinrude Johnson 3" Tach & System Check Gauge. New $125
2 Johnson/Evinrude Trim Indicator Gages New $50
1 Johnson/Evinrude lower unit Gasket #286279-2 New $20
1 Johnson/Evinrude Complete Gasket set #139300 fit 85 to 150 HP V4 motors New $50
2 Johnson/Evinrude Rubber Exhaust Gaskets fit 85 to 150 HP V4 motors New $10
6 Johnson/Evinrude Gaskets # 317914 fit 85 to 150 HP V4 motors New $6
1 Johnson/Evinrude Gasket # 359-317955-1 New $8
9 Johnson/Evinrude Gaskets # 194-321727-1 New $8
1 Johnson/Evinrude Gasket # 436-323459-1 New $8
5 Johnson/Evinrude Gasket # ???? New $6
1 Johnson/Evinrude drive shaft 85 to 150HP New $50
1 Johnson/Evinrude Clutch dog OEM #22683 OEM #319895 New $50
2 Johnson/Evinrude Helical Lower unit Gear sets # 340490 New $50
4 Johnson/Evinrude 90HP-150HP Rod Bearings set New $40
10 Brand New Valves for Inflateable Boats. New $20
1 CMC electric trim gage New $40
1 CMC. PT-130 Transom Clamp Motor Adapter (#13022) New $50
2 Aqua Power Impeller JP 28948-001OMC #509182 Fits Jabsco Seawater Used $10
2 Rubber Exhaust Gaskets New $5
1 Complete 90 Hp Gasket set # 139300 New $50
2 "used OMC Stator #583669, #583672, " New $50
2 "used JOHNSON/ Evinrude Stator #583669, #583672, " New $40
2 Johnson/Evinrude fuel fitings New $8
1 Johnson/Evinrude set of new plastic engine throttle connector slides New $10
1 Johnson/Evinrude used VRO Oil Tank with hose & Pump & Sender New $75
1 Fuel Fittings Set male & Female old style Merc New $15
1 Fuel Fitting Honda New $10
1 Fuel Fitting Suuzki New $10
Teleflex throttle/shift CABLES OMC Johnson/Evinrude NEW!
2 Teleflex Black 12ft t shift/throttle cable OMC New $12
1 Teleflex Black 15ft t shift/throttle cable OMC, Johnson/Evinrude New $15
3 Teleflex Black 12ft t shift/throttle cable Merc/Mariner New $12
3 Teleflex Black 16ft t shift/throttle cable Merc/Mariner New $16
1 Teleflex Black 23 ft shift/throttle cable MERC New $23
1 Teleflex Black plastic steering wheel New $10
1 remote steering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor.(May fit other brands) New $20
1 Plastic Pitot Tube pickup New $5
2 Battery Rotary Switchs used USED $10
1 pair of Standard Battery to Engine Cables Used $25
2 Johnson/Evinrude electric fuel chokes Used $25
1 Johnson/Evinrude 90 hp Carburator Used $30
1 Timer Base Kit #583376 Used $50
1 Johnson/Evinrude Rectifier Blue Power pack no part # Used $50
1 Johnson/Evinrude Rectifier/Regulator # CD4 #583336 23IM-0A Black Rectangle Used $100
1 Johnson/Evinrude Rectifier/Regulator #5114-04 DT-4 G Alum Metal Rectangle 3 wires? Used $50
1 Johnson/Evinrude Rectifier/Regulator # 395391 Used $75
1 Johnson/Evinrude pt/pt Relay Box with Cable Used $50
1 Recoil Starter Assembly for Merc/Force 9.9 or 15HP outboard motor. Used $50
1 factory service manualfor Merc/Force 9.9 or 15HP outboard motor. Used $40
4 Tilt Pins retainer Bars for Johnson/Evinrudes Used $10
2 Stainless Steel Steering arms for outboards Used $40
2 Stainless Steel Steering Coupler brackets Used $40
2 Johnson/Evinrude Ignition coils #582508-0560-0A Used $99
1 Johnson/Evinrude OMC Stator #583672 Used $75
1 Johnson/Evinrude OMC Stator #583669, Used $75
4 Johnson/Evinrude ignition coils Used $10
2 Johnson/Evinrude Flywheel Used $100
1 Johnson/Evinrud Shift/Throttle control Housing Used $40
1 Johnson/Evinrude Plastic Fuel Tanks Used $20
3 Johnson/Evinrude TRIM TAB (adjusts outboard torque) 327640 Used $20
1 Johnson/Evinrude throttle/shift control, missing a few minor parts Used $50
4 Johnson/Evinrude Big heavy Alum wedge Motor Mounting Brackets to shim up outboard on transom Used $25 each.
1 Johnson/Evinrude plastic throttle shift handle with pt/pt switch Used $20
1 Johnson/Evinrude plastic throttle handle. Used $15
1 Johnson/Evinrude complete wiring electrical harness with lots of electrical parts from Johnson 90HP V 4 Used $100
2 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs Used $50
2 Johnson/Evinrude Tachometer used Used $10
1 LOWRANCE Blue water Pro Flasher/Paper chart recorder Fishfinder with transducer. Used $100
1 RAYNAV 520 Loran with coupler Used $50
1 Apelco handheld GPS 15 with dashboard mounting bracket Used $50
1 Raytheon VHF/TV Anttena Dome Used $20
2 High Flyer RADAR Bouys Used $25 each
55 gal white poly drums with blue stripes good for mooring bouys Just $75 each
1 ONAN Temp Gage #129-8739 desc: AK21LB23 New $50
1 ONAN Temp Sender #7E-4279 desc: AK 25EB33 New $30
1 Adaptor # 9M-6522 Desc: FITAM26 New $6
1 TEE # 033-2177 Desc: FITDP08 New $20
1 ONAN Fuel/Oil Filter New $10
1 chilton Repair Manual Subaru Used $10
1 pair Large size indoor/Outdoor waterproof speakers used Used $30
1 pair Medium size indoor/Outdoor waterproof speakers used Used $20
1 Bronze 11/2 Prop Nut Used $5
1 Fuel Fittings Set male & Female old style Merc Used $10
Teleflex throttle/shift CABLES OMC Johnson/Evinrude USED Just $1 per foot. Used
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner Used $10
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner NEW $20
4 Teleflex Black 16ft t shift/throttle cable Merc/Mariner NEW $25
1 Teleflex Black 23ft t shift/throttle cable Merc/Mariner New $30
1 pair of Alum/Plastic oars for inflateable boat Used $10
2 Child class 3 life preservers Used $5 for both
4 Class I Life Preservers Used $20 each
1 30 inch USCG Approved Orange life ring Used $30
1 Teleflex Marine Trident Blue Wet Exhaust Hose 3 dia X 50 lg. Used $20
20 Heavy Battery Cables 2 ft long with ring lugs Just $10 Each Used $10
1 Raytheon Marine Electronics Factory Service Marine set of 2 Used $20
2 Alum Dingy Davit Brackets ( 2pcs mount on transom & 2 pieces mount on dingy NEW $150
(Can ship to you)
Sold My Chevy Z71 Tahoe & GMC K1500 Pickup so I don't need these spare parts.
All Parts are NEW!
Chevy/GMC 5.7ltr Serpintine Belt. $20
Bosch Fuel Filter In tank fuel filter for Chevy/GMC z71. $4
In tank fuel check valve for Chevy/GMC z71. $4
Perfect Circle Exhaust Valve for Chevy 350. $5
Set of vale stem seals for Chevy 350. 4
"Oil Filter for Chevy 350/305 $3
Chiltons Subaru 1970 to 1982 service manual. $5
Chevy/GMC K1500 rear brake spring kit. $5
Chevy/GMC Thermostat. $4
Chevy/GMC Clutch or Brake Pedal Rubber Pad $2
2 pieces of 2inch exhaust tips Just $4 each
2 pieces of 2inch exhaust elbows Just $4 each
Brake Cylinder for Chevy/Buick $8
Fuel filter Chevy 350 $4
ACCELL High Voltage Ignition Coil New in Box $40.
ACCELL Distributor & Rotors Caps for Mallory $12. set.
ACCELL Distributor advance kit with springs $2
Set of Mallory Duel Points for Mallory Marine Dist $4.
Complete rear tail light assy for 1988 Buik T Type cars. Just $20
Oil filter for a Ford 351 engine $2.
Oil filters for Chevy/GMC 454 engine $2ea
Oil Filter for Chevy 350/305 $2
Felpro Chevy 305/350 4 boat rubber valve cover gaskets 1 pair PN# VS12869R New $10.
Felpro Chevy 305/350 Cork/rubber valve cover gasket 1each New. $2
NEA PN# VS2335 Chevy 305/350 4 boat Marine Exhaust Manifold gaskets. New. 1 pair . $10.
Felpro Mercrusier Chevy 305/350 Gasket kit assorted not complete (head gasket missing) $10.
Gasket Set for Holly 650 Marine Carb $2
Raybestos BruteStop Series BD369M Front Disc Brake Pad Set. Just $30
Fits these Vehicles
• 1993-1993 Cadillac 60 Special
• 1990-1993 Cadillac Commercial Chassis
• 1990-1999 Cadillac DeVille
• 1999-2000 Cadillac Escalade
• 1990-1992 Cadillac Fleetwood
• 1990-2002 Chevrolet Astro
• 1992-1994 Chevrolet Blazer
• 1988-1999 Chevrolet C1500
• 1992-1999 Chevrolet C1500 Suburban
• 1988-2000 Chevrolet C2500
• 1992-1993 Chevrolet C2500 Suburban
• 1996-2002 Chevrolet Express 1500
• 1996-2002 Chevrolet Express 2500
• 1988-1999 Chevrolet K1500
• 1992-1999 Chevrolet K1500 Suburban
• 1988-2000 Chevrolet K2500
• 1992-1993 Chevrolet K2500 Suburban
• 1995-2000 Chevrolet Tahoe
• 1994-1999 Dodge Ram 1500
• 1988-1999 GMC C1500
• 1992-1999 GMC C1500 Suburban
• 1988-2000 GMC C2500
• 1992-1993 GMC C2500 Suburban
• 1988-1999 GMC K1500
• 1992-1999 GMC K1500 Suburban
• 1988-1996 GMC K2500
• 1992-1993 GMC K2500 Suburban
• 1990-2002 GMC Safari
• 1996-2002 GMC Savana 1500
• 1996-2002 GMC Savana 2500
• 1992-1999 GMC Yukon
• 1999-2000 GMC Yukon Denali
Two Alum Clutch/Brake handles New for Yamaha RD Model bikes $10 both
Two new Oil filters for Yamaha XS 1100 model bikes $10 both
Good used electric horn and bracket from Yamaha XS 1100 $30.
Southern MAINE! Can Ship to you.
Will consider Trades WANTED: A couple new late model Recurve Bows. Left hand and RH
Leather Quivers, Arrows, Targets, Reloading primers and 80 class fishing reels and other sportsman items •Location: Southern MAINE! Can Ship to you.
post-8420-0-45701800-1370347627_thumb.jp
post-8420-0-68571400-1370347658_thumb.jp
post-8420-0-54836600-1370347671_thumb.jp
post-8420-0-19549400-1370347696_thumb.jp
post-8420-0-57146600-1370347717_thumb.jp
post-8420-0-29282500-1370347762_thumb.jp
post-8420-0-09742300-1370348127_thumb.jp
