Outboard Motor Parts
Outboard Motor Parts for OMCs JOHNSON 85,90,100,110,115,130,150 hp outboards.
And some other items. (Outboard Motor parts came from a closed repair shop down in Mass)
Current List as of 06/03/2015
I need to get al this stuff out of my basemet.
Make me an offer. Will consider trades of equal value of the following items new small 4/5 Hp 4 stroke outboard motor, 16-17 ft welded Alum boat, Woodsplitter, hyd dump trailer, quality firearms or CASH
QTY DESCRIPTION New/Used Price Ea. Extended Price
1 Teleflex SeaStar steering Hydraulic Helm Tel Part# . New $495.
3 Water Pump Impeller Teleflex 18-3056 Impeller - Dia. 3 1/2",Dpth. 1 1/4" - 6 Fins - Neoprene
Honda # 06192-ZW1-00 Fits Honda 75HP and Mercs 4743026-2 and others. New Just $12.ea. take all 3 for $30.
2 Johnson/Evinrude VRO hose & Sender New $100
1 Johnson/EvinrudeTRIM TAB 327640 OMC New $10.
3 Johnson/Evinrude #323664 Spline Gear New $99. ea
3 Helical Lower unit Gear sets 340490 New $199. ea
1 Johnson/Evinrude New Rectifier/Regulator Kit # 395391 New $150. ea
1 Johnson/Evinrude Ignition Coil Kit # 583737 New $99.ea
2 Johnson/Evinrude Ignition coils #582508-0560-0A New $25. ea
2 Johnson/Evinrude POWER PACKS OMC CD4 584027 New $85. ea.
1 Johnson/Evinrude Voltage Regulator Kit # 173640 New $189.ea.
2 Johnson/Evinrude Timer Base Kit #583376 New $200.ea.
Johnson/Evinrude Complete Water Pump kit for ? HP #391391 New $50. ea.
Johnson/Evinrude CompleteWater Pump kit for 85-150 HP Part # New $50. ea.
Johnson/Evinrude Evinrude Johnson 3" Tach & System Check Gauge. New $150. ea.
2 Johnson/Evinrude Trim Indicator Gages New $50. ea.
1 Johnson/Evinrude lower unit Gasket #286279-2 New $20. ea
2 Johnson/Evinrude Rubber Exhaust Gaskets fit 85 to 150 HP V4 motors New $10.ea
6 Johnson/Evinrude Gaskets # 317914 fit 85 to 150 HP V4 motors New $6.ea.
1 Johnson/Evinrude Gasket # 359-317955-1 New $8.ea.
9 Johnson/Evinrude Gaskets # 194-321727-1 New $8. ea.
1 Johnson/Evinrude Gasket # 436-323459-1 New $8. ea.
5 Johnson/Evinrude Gasket # ???? New $6. ea.
2 Johnson/Evinrude Helical Lower unit Gear sets # 340490 New $199.ea.
4 Johnson/Evinrude 90HP-150HP Rod Bearings set New $50. ea.
10 Brand New Valves for Inflateable Boats. New $25 ea.
2 Aqua Power Impeller JP 28948-001OMC #509182 Fits Jabsco Seawater Used $20 $40
3
Teleflex 18-3056 Impeller Dia. 3 1/2",Dpth. 1 1/4" 6 Fins NeopreFits Honda 75 to 150 and Mercs and others. New $17 $51
3 #323664 Spline Gear $99.ea. New $99 $297
1 Ignition Coil Kit # 583737 New $99 $99
1 Voltage Regulator Kit # 173640 New $189 $189
2 Helical Lower unit Gear sets 340490 New $199 $199
2 Rubber Exhaust Gaskets New $10 $20
1 Complete 90 Hp Gasket set # 139300 New $50 $50
1 Gaskets # 317914 New $6 $6
2 used OMC Stator #583669, #583672,
New $50 $100
2 used JOHNSON/ Evinrude Stator #583669, #583672, New $40 ea.
1 Johnson/Evinrude Zinc TRIM TAB 327640 New $20
2 Johnson/Evinrude New $50 $100
2 Johnson/Evinrude fuel fitings New $8 $16
1 Johnson/Evinrude set of new plastic engine throttle connector slides New $20 $20
1 Johnson/Evinrude VRO Oil Tank with hose & Pump & Sender New $100.
1 Fuel Fittings Set male & Female old style Merc New $15 $100
1 Fuel Fitting Honda New $10
Teleflex throttle/shift CABLES OMC Johnson/Evinrude Just $1 per foot. New
2 Teleflex Black 12ft t shift/throttle cable OMC New $15 $30
1 Teleflex Black 15ft t shift/throttle cable OMC, Johnson/Evinrude New $15.
1 Teleflex Black 23 ft shift/throttle cable MERC New $25. ea
1 Teleflex Black plastic steering wheel New $15 $15
1 remote steering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor. ( May fit other brands) New $100..
2 Battery Rotary Switchs New $25. ea.
2 Johnson/Evinrude electric fuel chokes Used $25. ea.
1 Timer Base Kit #583376 Used $100.
1 Johnson/Evinrude Rectifier/Regulator # 395391 Used $85.
1 Recoil Starter Assembly for Merc/Force 9.9 or 15HP outboard motor. Used $50.
1 factory service manualfor Merc/Force 9.9 or 15HP outboard motor. Used $40 $40
4 Tilt Pins retainer Bars for Johnson/Evinrudes Used $20 $80
2 Stainless Steel Steering arms for outboards Used $40 $80
2 Stainless Steel Steering Coupler brackets Used $40 $80
2 Johnson/Evinrude Ignition coils #582508-0560-0A Used $99 $99
1 Johnson/Evinrude OMC Stator #583672 Used $75 $75
1 Johnson/Evinrude OMC Stator #583669, Used $75 $75
4 Johnson/Evinrude ignition coils Used $10 $20
2 Johnson/Evinrude Flywheel Used $100 $200
1 Johnson/Evinrud Shift/Throttle control Housing $40 Used $40 $40
1 Johnson/Evinrude Plastic Fuel Tanks Used $20 $20
3 Johnson/Evinrude TRIM TAB (adjusts outboard torque) 327640 Used $20 $60
1 Johnson/Evinrude throttle/shift control Used $50 $50
`1 Johnson/Evinrude throttle/shift control, missing a few parts Used $25 $25
4 Johnson/Evinrude Big heavy Alum wedge Motor Mounting Brackets to shim up outboard on transom Used $25 ea.
2 Johnson/Evinrude Tachometer used Used $10 $20
1 LOWRANCE Blue water Pro Flasher/Paper chart recorder Fishfinder with transducer. Used $150 $150
1 RAYNAV 520 Loran with coupler Used $50
1 Apelco handheld GPS 15 with dashboard mounting bracket Used $100.
1 Raytheon VHF/TV Anttena Dome Used $50 $50
Used
Factory & Aftermarket Marine Outboard Motor Repair Manuals Johnson, Force, Subaru Used $10.
$40
1 pair Large KLH indoor/Outdoor waterproof speakers used Used $50
1 pair Small KLH indoor/Outdoor waterproof speakers used Used $30.
1 Bronze 11/2 Prop Nut Used $5 $5
1 Fuel Hose with Fuel Fittings & Primer old style Merc Used $10 $10
1 Fuel Fittings Set male & Female old style Merc Used $10 $10
1 pair of Alum/Plastic oars for inflateable boat Used $20 $20
WickedGoodOutdoors@MAine.rr.com
post-8420-0-55123500-1341405165_thumb.jp
post-8420-0-60912600-1341405516_thumb.jp
post-8420-0-20609900-1341405528_thumb.jp
post-8420-0-69564400-1341405541_thumb.jp
post-8420-0-89416800-1341405554_thumb.jp
post-8420-0-58605200-1341405567_thumb.jp
post-8420-0-91862300-1341405573_thumb.jp
post-8420-0-91057600-1341405578_thumb.jp
post-8420-0-02070800-1341405602_thumb.jp
Edited by WickedGoodOutdoors
  • 10 months later...
PRICES REDUCED!
FOR SALE:
Email Me with your REAL name and Email address or I will not respond Southern MAINE! can ship to you)
I sold my outboard motors and Chevys, no longer have a need for these spare parts.
Bunch of new & Used Outboard Boat Parts and Other Things for sale.
Make me an Offer for One part or the WHOLE LOT!
Send me an Email with your Real E mail
Parts for outboards (Can ship)
use your real Email address Ill send you a list of everything I have and pictures.
Outboard Motor Parts for OMCs JOHNSON 60,70,85,90,100,110,115,130,150 hp outboards. And others
90 Degree loopcharged years 1985 thru 1998
New Ignition Keys for Mercury/Force outboards! Various keys.
1 Teleflex SeaStar steering Hydraulic Helm Tel Part# hh5271 1.7, 6.9mpa 100psi $495.
1 Apelco handheld GPS 15 with dashboard mounting bracket Used $50
1 Raytheon VHF/TV Anttena Dome Used $20
2 High Flyer RADAR Bouys Used $25 each
55 gal white poly drums with blue stripes good for mooring bouys Just $50. each
1 ONAN Temp Gage #129-8739 desc: AK21LB23 New $50
1 ONAN Temp Sender #7E-4279 desc: AK 25EB33 New $30
1 Adaptor # 9M-6522 Desc: FITAM26 New $6
1 TEE # 033-2177 Desc: FITDP08 New $20
1 ONAN Fuel/Oil Filter New $10
1 chilton Repair Manual Subaru Used $10
1 pair Large size indoor/Outdoor waterproof speakers used Used $50
1 pair Medium size indoor/Outdoor waterproof speakers used Used $30.
Teleflex throttle/shift CABLES OMC Johnson/Evinrude USED Just $1 per foot. Used
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner Used $10
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner NEW $20
4 Teleflex Black 16ft t shift/throttle cable Merc/Mariner NEW $25
1 Teleflex Black 23ft t shift/throttle cable Merc/Mariner New $30
1 pair of Alum/Plastic oars for inflateable boat Used $10
1 Teleflex Marine Trident Blue Wet Exhaust Hose 3 dia X 50 lg. Used $20
20 Heavy Battery Cables 2 ft long with ring lugs Just $10 Each Used $10
1 Raytheon Marine Electronics Factory Service Marine set of 2 Used $20
2 Alum Dingy Davit Brackets ( 2pcs mount on transom & 2 pieces mount on dingy NEW $150
(Can ship to you)
Sold My Chevy Z71 Tahoe & GMC K1500 Pickup so I don't need these spare parts.
All Parts are NEW!
Chevy/GMC 5.7ltr Serpintine Belt. $20
Bosch Fuel Filter In tank fuel filter for Chevy/GMC z71. $4
In tank fuel check valve for Chevy/GMC z71. $4
Chiltons Subaru 1970 to 1982 service manual. $10.
Chevy/GMC K1500 rear brake spring kit. $5
Chevy/GMC Thermostat. $4
Chevy/GMC Clutch or Brake Pedal Rubber Pad $2
ACCELL High Voltage Ignition Coil New in Box $40.
Set of Mallory Duel Points for Mallory Marine Dist $4.
Oil filters for Chevy/GMC 454 engine $2ea
Oil Filter for Chevy 350/305 $2
NEA PN# VS2335 Chevy 305/350 4 boat Marine Exhaust Manifold gaskets. New. 1 pair . $10.
Felpro Mercrusier Chevy 305/350 Gasket kit assorted not complete (head gasket missing) $10.
Two Alum Clutch/Brake handles New for Yamaha RD Model bikes $30 both
Two new Oil filters for Yamaha XS 1100 model bikes $10 both
Good used electric horn and bracket from Yamaha XS 1100 $30.
Southern MAINE! Can Ship to you.
Will consider Trades WANTED: A couple new late model Recurve Bows. Left hand and RH
Leather Quivers, Arrows, Targets, Reloading primers and 80 class fishing reels and other sportsman items •Location: Southern MAINE! Can Ship to you.
  • 1 year later...
