Albury Brothers Boats
Best 23 mono hull Ive ever had the opportunity to own.. Love that sharp entry that cuts right through the water like a hot knife on butter. The spray rails keep you so dry...and the ride is almost like a cat coming off a wave...soft re-entry every time..
So they are not self bailing?
You can't see the scuppers in that photo. Look at the transom photo.
Its a great set up. There is also a plug in that bilge section that you can pull and run with it out. Everything drains to that section, water, blood, scales..etc, the pump does what its intended for if you desire to use it..and can also be lifted out with its mounting plate on top of the deck if need be to clean that area... or there is a switch to disable it. Totally Self bailing, plug is at water line..deck is above that, and there is also a bilge plug, underneath that, but I never had 1 drop of water below the deck. Here are a few pics showing both the drain plugs, and relationship of the waterline as the boat sits in the water. Id rather have a system that I can see, have easy access to, vs having to go below a deck, or through a inspection plate to check if my bilge is working or not. Jeff
post-3244-0-32333900-1299239015_thumb.jp
post-3244-0-47654700-1299239098_thumb.jp
post-3244-0-46945300-1299239216_thumb.jp
Edited by Jassman
